I'm sure there are some people on this Forum that use Renogy Rover MMPT controllers.
After days of hair pulling followed by hours of research I found that the default settings for the Renogy Rover with LFP battery is very-very bad.
As many have posted on the DIY-SOLAR forum and other places, the best fix is to select USER mode instead of LI (LFP) for the battery settings. Then you can customized the charge/float and protection voltages properly.
The default LI settings will cause the SCC to go over-voltage followed by reset and in a loop. Voltages of over +15v are sent to the battery which can damage equipment connected to it.
You can read more here:
https://diysolarforum.com/threads/renog ... ost-606395
Renogy Rover Li BAD Settings Issue
ronmackaypei
