Well I plugged my SolarDashboard back in and all worked nicely for about half an hour then the problems resumed again with missing data then shortly afterwards it all stopped again!
Glad we solved the problem, I think we can give the solar dashboard an update to make it set the ID to 1 automatically. Hopefully this fixed this issue.
Jon
Any idea when I can expect to receive the replacement unit Jon
Hello there,
solar dashboard is working flawlessly. I have question though or maybe idea for future updates, is there any chance to have temperature of the batteries from the sensor connected to charge controller displayed somewhere on the dashboard? other question, is there a way to program in togle switch that can turn load side of the charge controller on and off via dashboard? And one more thing at the end, any way adjusting range of the graphs manualy,for example i have 1.5 amps coming from solar panels but 9 amps from charge controller, on graph they are not proportianly dispalyed to each other because of the automatic scaling, in fact they are preatty much tracking on top of each other and graph is not usable.
Thanks
Thanks
Hi all, does anyone know whats happened to Jonathan?
TripitakaBC
Hi Guys, thanks for the concern. We are all good. Just busy with some other projects which will be wrapped up soon. Any specific inquiries about the status of your order, please send an email. We appreciate your patience.
Thanks,
Amente
Thanks,
Amente
TripitakaBC wrote: ↑Mon Mar 15, 2021 11:42 amNo but it did seem strange that the admin aspect of the forums have gone into hiatus.
@jonathan @david @amente - You guys OK?
Thanks for your concern, we are good. How's everything on the farm?
Earlier this year we added the big feature to the cloud software to allow multiple dashboards under one account. It works, but there's some graphical glitches we need to work out. We had to develop it in a hurry due to a customer ordering multiple +++ dashboards. After this we have to take a bit of a pause on development to catch up on other work. Keep in mind we are adding users to the solar dashboard community continuously!
Thanks for your continued support and involvement, want to get to your feature requests soon but some of them are not trivial!
TripitakaBC
Happy to hear that you are just busy due to growing business! All good here, spring is coming in fast which brings a ton of work so I appreciate your situation; there is never enough time to get everything done.
It's a funny old world, if I went missing my buddies may not notice for a month but my suppliers and customers would notice inside a couple of days.
