It's true!TripitakaBC wrote: ↑Tue Mar 16, 2021 9:22 amHappy to hear that you are just busy due to growing business! All good here, spring is coming in fast which brings a ton of work so I appreciate your situation; there is never enough time to get everything done.
It's a funny old world, if I went missing my buddies may not notice for a month but my suppliers and customers would notice inside a couple of days.![]()
That is frustrating, I really did send it. I'll have to send another one.
Thank you, Do you have any tracking info Jonathan
OK, no problem. Do you have any idea of the date I should expect to receive it.
I think 1-2 weeks from now
Hi Jonathon, new box arrived the other day and I now have it up and running so fingers crossed I no longer have the issues I've had in the past.
Thanks again for sorting me out with a replacement unit.
1 question to help me with the final setup, how do I set MQTT Username/Password, when using the MQTT option to communicate with Home Assistant, HA rejects the connection because it requires a Username/Password but I do not see anywhere to set it within the SolarDashboard.
I get this in my HA log even if I turn of the password requirement within the MQTT in Home Assistant
1618303942: New client connected from 192.168.1.114 as SnekTek-SolarDashboard-6519446 (p2, c1, k15).
1618303942: Socket error on client SnekTek-SolarDashboard-6519446, disconnecting.
Any thoughts or do any other members have any experience with this
