Is My Dead SnekTek Solar Dashboard Recoverable?
ellomoto
Post by ellomoto »
Hi
My solar dashboard worked flawlessly and has stopped working correctly.
Below is a video clip of the light activity when powered on.
https://www.canva.com/design/DAE4nazGP2 ... esignpanel
The local wifi network is created OK and I can connect my devices to it and obtained an IP address. I can ping the Gateway 192.168.4.1 address OK from my computer.
However the Dashboard page on 192.168.4.1 is not loaded or displayed, which is as far as I can get. I have tried connecting with IOS, Android, PC and MAC using different browsers and the result is the same.
Can you help?
Cheers
Re: Is My Dead SnekTek Solar Dashboard Recoverable?
Hi,
Yes it's working ok. Follow the firmware flashing instructions to flash a new firmware with the micro USB cable. This will reset the web page so you can access it.
ellomoto
Post by ellomoto »
Thanks for the update Jonathan. That worked a treat. My device is now working again!
