That's great news, I will be waiting with bated breath.xion2000 wrote: ↑Wed Jan 29, 2020 9:23 pm@xion2000, that is an interesting use case. We are looking into adding a feature to the snektek wifi dashboard which enables it to send data to home assistant via MQTT broker. That way you should be able to use the data from the dashboard in Home Assistant. Stay tuned.
[/quote]
@xion2000, I also looked more into Home Assistant and noticed that there is also a Restful API integration (https://www.home-assistant.io/integrations/rest/), you should be able to get data from solar dashboard to use in Home Assistant by sending a request to http://<SOLAR-DASHBOARD-IP>/cur_data , this gives you the current data in JSON format.
