Dobster
Post by Dobster » Sun Jul 19, 2020 2:28 pm
okay I tried the new card, now this one gives me the not initialized error. Put old one back in and it is now doing the same.
Post by jonathan » Sun Jul 19, 2020 2:52 pm
Hey I can see now that you have some graphs working on the cloud, that means the card is working?
Dobster
Post by Dobster » Sun Jul 19, 2020 3:14 pm
Yes, I got it working.Here's what I did.
I powered off dashboard removed the sd card, then i removed the battery to make sure i got a clean restart, reinserted the sd card then inserted the battery, plugged back into charge controller. Everything seems to be working fine now.
Thanks
Post by jonathan » Sun Jul 19, 2020 3:23 pm
Thanks
Awesome glad it's working.
You'll notice the gauge is now auto scaled, it uses the maximums from the chart to determine the scale.
You're making quite a bit of power, is this for an off grid house?
Dobster
Post by Dobster » Sun Jul 19, 2020 3:45 pm
I'm still tied to the grid, slowly becoming less dependent on the grid, by moving circuits from the grid to my solar. I have 4 kilowatts of solar, but only have half of them online now, as I recover from my little health issue I'll get the rest up and running. I also have 16 kwh of lipo4 battery backup.
I'm liking the setup so far.
Dobster
Post by Dobster » Sun Jul 19, 2020 4:11 pm
Well everything was working, its quit again....
What now?
Post by jonathan » Sun Jul 19, 2020 4:15 pm
What now?
Hey if everything looks ok on the local connection, go to the cloud tab again and re-enter the username and API key. The SD card needs to be working when the credentials are entered or they are not saved on the SD card. I think in your case you entered the credentials when the card was inop.
If you want to verify, you can check on the SD card it will create a config file with the credentials. They should be there or the cloud will disconnect next time the unit reboots.
Dobster
Post by Dobster » Sun Jul 19, 2020 4:30 pm
Its not even working on the local machine now. The yellow light has quit flashing, only have a red light even after restarting.
Post by jonathan » Mon Jul 20, 2020 2:13 pm
Ok we got you running again. Any more issues?
boffin
Post by boffin » Wed Jul 29, 2020 12:17 am
Just a quick Thankyou - upgraded the firmware this morning and what a great result. Even via a dodgy WiFi connection it was quick. All confit details details work well and now being via the app. makes it all a little easier not having to pull the SD to update the txt file. Well done.
