Post by fredivar » Tue Sep 08, 2020 6:27 am
I guess I should do the HW modification with regards to SD card reset too, since my board was bought back in May 2019. I see pictures of the mod on page 8, but was it a list of components needed too on some page?
Post by jonathan » Tue Sep 08, 2020 10:47 am
You need some wire, a 100uf capacitor, a 3906 p type transistor or similar mosfet.
accel
Post by accel » Wed Sep 09, 2020 1:13 pm
My solar setup ran abolutely fine until this morning.
The solar dashboard log now say this:
[sd_card]: Wrote one sample to: 2020/09/09/data.txt 09-09-2020 05:33:59
[mqtt_client]: publishing data to topic: solar Failed 09-09-2020 05:33:59
[mqtt_client]: publishing data to topic: solar Failed 09-09-2020 05:34:09
[mqtt_client]: publishing data to topic: solar Failed 09-09-2020 05:34:19
[mqtt_client]: publishing data to topic: solar Failed 09-09-2020 05:34:29
[mqtt_client]: publishing data to topic: solar Failed 09-09-2020 05:34:39
[mqtt_client]: publishing data to topic: solar Failed 09-09-2020 05:34:49
[sd_card]: Wrote one sample to: 2020/09/09/data.txt 09-09-2020 05:34:59
[mqtt_client]: publishing data to topic: solar Failed 09-09-2020 05:34:59
[mqtt_client]: publishing data to topic: solar Failed 09-09-2020 05:35:09
[mqtt_client]: publishing data to topic: solar Failed 09-09-2020 05:35:19
[mqtt_client]: publishing data to topic: solar Failed 09-09-2020 05:35:29
[mqtt_client]: publishing data to topic: solar Failed 09-09-2020 05:35:39
[mqtt_client]: publishing data to topic: solar Failed 09-09-2020 05:35:49
earlier this morning everything was still fine:
[sd_card]: Wrote one sample to: 2020/09/09/data.txt 09-09-2020 05:05:59
[mqtt_client]: publishing data to topic: solar OK 09-09-2020 05:05:59
[mqtt_client]: publishing data to topic: solar OK 09-09-2020 05:06:09
[mqtt_client]: publishing data to topic: solar OK 09-09-2020 05:06:19
[mqtt_client]: publishing data to topic: solar OK 09-09-2020 05:06:29
[mqtt_client]: publishing data to topic: solar OK 09-09-2020 05:06:39
[mqtt_client]: publishing data to topic: solar OK 09-09-2020 05:06:49
[sd_card]: Wrote one sample to: 2020/09/09/data.txt 09-09-2020 05:06:59
[mqtt_client]: publishing data to topic: solar OK 09-09-2020 05:06:59
[mqtt_client]: publishing data to topic: solar OK 09-09-2020 05:07:09
[mqtt_client]: publishing data to topic: solar OK 09-09-2020 05:07:19
[mqtt_client]: publishing data to topic: solar OK 09-09-2020 05:07:29
[mqtt_client]: publishing data to topic: solar OK 09-09-2020 05:07:39
[mqtt_client]: publishing data to topic: solar OK 09-09-2020 05:07:49
Still the mqtt client does not publish any data.
The mosquitto broker on my raspberry pi still runs ok, no problems connecting to it.
I did not change a thing in my setup. What could be causing this problem?
Thanks in advance!
Post by fredivar » Fri Sep 11, 2020 3:56 pm
fredivar wrote:
Mon Sep 07, 2020 7:21 am
Ok, I looked into logs, but did not see that. I expected that the missing charts was due to auto range in the new firmware and it needed some time before proper curves was available. Then I need to change the SD, but not possible before going to my summer house hopefully next weekend. So there is no way to get my charts to work without new SD card?
Back in summer house this weekend, and tried different SD cards, but still no charts, only instant values.
The parameters set in the SD card works correctly, but looking into the SD card it contains a folder "2031“ with a subfolder" 9" with again another "6" as third level subfolder. This is obviously Year with Month in subfolder and Day as third level. And looking into log below this makes sense (but is of course wrong) :[some values removed to prevent hacking]
[sd_card]: Resetting power 00-00-1970 00:00:00
[sd_card]: Found config key value pair apSSID=xxxxx 00-00-1970 00:00:00
[sd_card]: Found config key value pair apPassword=xxxxxxx 00-00-1970 00:00:00
[sd_card]: Found config key value pair mqttServer=test.mosquitto.org 00-00-1970 00:00:00
[sd_card]: Found config key value pair mqttTopic=exampleTopic 00-00-1970 00:00:00
[sd_card]: Found config key value pair cloudUser=fredi.tallaksen@gmail.com 00-00-1970 00:00:00
[sd_card]: Found config key value pair cloudApiKey=xxxxx-xxxxxxx-xxxxx-xxxxxx-xxxxxx 00-00-1970 00:00:00
[sd_card]: Found config key value pair debugEnabled=1 00-00-1970 00:00:00
[clock]: I2C is initialized for RTC use 00-00-1970 00:00:00
[main]: Initial setup ...... 13-09-2031 15:58:09
[main]: Firmware version: 4.0-4c05ee-2020-09-06-01-00 13-09-2031 15:58:09
[main]: HTTP server started on port: 80 13-09-2031 15:58:09
[clock]: RTC epoch: 1947081489 13-09-2031 15:58:09
[clock]: NTP epoch 1 13-09-2031 15:58:09
[clock]: NTP epoch 2 13-09-2031 15:58:09
[clock]: NTP epoch 3 13-09-2031 15:58:09
[clock]: NTP time was not available 13-09-2031 15:58:09
[clock]: RTC time is NOT synchronized with NTP 13-09-2031 15:58:09
[mqtt_client]: Configuring ... 13-09-2031 15:58:09
[mqtt_client]: Configured with server test.mosquitto.org :1883 13-09-2031 15:58:09
[reboot_stat]: lastUpdatedTime: 1947081489 rebootCount: 31 rebootCause: NORMAL 13-09-2031 15:58:09
[updater]: Checking for updates, retry=1/5 13-09-2031 15:58:09
[updater]: Failed to connect to mysolardashboard.snektek.com:8123 13-09-2031 15:58:09
[updater]: Update check result: failed_to_connect 13-09-2031 15:58:09
[updater]: Checking for updates, retry=2/5 13-09-2031 15:58:09
[updater]: Checking for updates, retry=3/5 13-09-2031 15:58:09
[updater]: Connected to mysolardashboard.snektek.com:8123 13-09-2031 15:58:09
[updater]: Update check[cloud_sync] Connected to mysolardashboard.snektek.com:8123 13-09-2031 15:58:09
[cloud_sync]: syncRequest.curData: 0 13-09-2031 15:58:09
[cloud_sync]: syncRequest.config: 0 13-09-2031 15:58:09
[cloud_sync]: syncRequest.version: 0 13-09-2031 15:58:09
[cloud_sync]: syncRequest.wifiStatus: 0 13-09-2031 15:58:09
[cloud_sync]: syncRequest.rebootStatus: 0 13-09-2031 15:58:09
[cloud_sync]: syncRequest.updateCheck: 0 13-09-2031 15:58:09
[clock]: NTP epoch 1599847607 13-09-2031 15:58:09
[clock]: RTC time is synchronized with NTP 13-09-2031 15:58:09
[main]: WiFi.isConnected(): 1 WiFi.localIP(): 192.168.8.101 13-09-2031 15:58:09
[mqtt_client]: Attempting a new connection ... 13-09-2031 15:58:09
[mqtt_client]: Attempting to connect with a clientId: SnekTek-SolarDashboard-6546524 13-09-2031 15:58:09
[mqtt_client]: Failed to connect 13-09-2031 15:58:09
[cloud_sync]: syncRequest.curData: 1 13-09-2031 15:58:09
[cloud_sync]: syncRequest.config: 1 13-09-2031 15:58:09
[cloud_sync]: syncRequest.version: 1 13-09-2031 15:58:09
[cloud_sync]: syncRequest.wifiStatus: 1 13-09-2031 15:58:09
[cloud_sync]: syncRequest.rebootStatus: 1 13-09-2031 15:58:09
[cloud_sync]: Sending file cur_data.json to mysolardashboard.snektek.com:8123 13-09-2031 15:58:09
[cloud_sync]: Sending file version.json to mysolardashboard.snektek.com:8123 13-09-2031 15:58:09
[cloud_sync]: Sending file rebootStatus.json to mysolardashboard.snektek.com:8123 13-09-2031 15:58:09
[cloud_sync]: Sending file wifi_info.json to mysolardashboard.snektek.com:8123 13-09-2031 15:58:09
[cloud_sync]: Sending file config.json to mysolardashboard.snektek.com:8123 13-09-2031 15:58:09
[cloud_sync]: File not found: 2020/09/11/data.txt 13-09-2031 15:58:09
[cloud_sync]: File not found: 2020/09/10/data.txt 13-09-2031 15:58:09
[cloud_sync]: File not found: 2020/09/09/data.txt 13-09-2031 15:58:09
[cloud_sync]: File not found: 2020/09/08/data.txt 13-09-2031 15:58:09
[cloud_sync]: File not found: 2020/09/07/data.txt 13-09-2031 15:58:09
[cloud_sync]: File not found: 2020/09/06/data.txt 13-09-2031 15:58:09
[cloud_sync]: File not found: 2020/09/05/data.txt 13-09-2031 15:58:09
[cloud_sync]: File not found: 2020/09/04/data.txt 13-09-2031 15:58:09
[cloud_sync]: File not found: 2020/09/03/data.txt 13-09-2031 15:58:09
[cloud_sync]: File not found: 2020/09/02/data.txt 13-09-2031 15:58:09
[cloud_sync]: File not found: 2020/09/01/data.txt 13-09-2031 15:58:09
[cloud_sync]: File not found: 2020/08/31/data.txt 13-09-2031 15:58:09
[cloud_sync]: File not found: 2020/08/30/data.txt 13-09-2031 15:58:09
[cloud_sync]: File not found: 2020/08/29/data.txt 13-09-2031 15:58:09
[cloud_sync]: File not found: 2020/08/28/data.txt 13-09-2031 15:58:09
[cloud_sync]: File not found: 2020/08/27[mqtt_client]: Attempting a new connection ... 13-09-2031 15:58:09
[cloud_sync]: File not found: 2020/08/21/data.txt 13-09-2031 15:58:09
[cloud_sync]: File not found: 2020/08/20/data.txt 13-09-2031 15:58:09
[cloud_sync]: File not found: 2020/08/19/data.txt 13-09-2031 15:58:09
[cloud_sync]: File not found: 2020/08/18/data.txt 13-09-2031 15:58:09
[cloud_sync]: File not found: 2020/08/17/data.txt 13-09-2031 15:58:09
[cloud_sync]: File not found: 2020/08/16/data.txt 13-09-2031 15:58:09
[cloud_sync]: File not found: 2020/08/15/data.txt 13-09-2031 15:58:09
[cloud_sync]: File not found: 2020/08/14/data.txt 13-09-2031 15:58:09
[cloud_sync]: File not found: 2020/08/13/data.txt 13-09-2031 15:58:09
[cloud_sync]: File not found: 2020/08/12/data.txt 13-09-2031 15:58:09
[cloud_sync]: File not found: 2020/08/11/data.txt 13-09-2031 15:58:09
[cloud_sync]: File not found: 2020/08/10/data.txt 13-09-2031 15:58:09
[cloud_sync]: File not found: 2020/08/09/data.txt 13-09-2031 15:58:09
[cloud_sync]: File not found: 2020/08/08/data.txt 13-09-2031 15:58:09
[cloud_sync]: File not found: 2020/08/07/data.txt 13-09-2031 15:58:09
[cloud_sync]: File not found: 2020/08/06/data.txt 13-09-2031 15:58:09
[cloud_sync]: File not found: 2020/08/05/data.txt 13-09-2031 15:58:09
[cloud_sync]: File not found: 2020/08/04/data.txt 13-09-2031 15:58:09
[cloud_sync]: File not fo[
I assume either this must be issue with the RTC og synchronization with NTP? Any help to get this correct please.
Post by jonathan » Fri Sep 11, 2020 4:13 pm
Hi Fred, I looked at your original order and you didn't opt for the RTC addon at the time, did you add it after? Otherwise the missing RTC explains these issues. The current firmware depends on the RTC but the old one didn't yet.
The firmware needs to be updated to identify a failed/missing RTC and fallback possibly.
I think the SD card is working ok probably.
Post by jonathan » Fri Sep 11, 2020 4:14 pm
Thanks in advance!
Hi accel, it's a bit limited your information. I would think maybe internet interruption caused this. Did it start working later?
Post by fredivar » Fri Sep 11, 2020 4:18 pm
Looking closely on my Snektek module which is V2 with a RTC pinout, but no special RTC module (which I saw in another YouTube video). Since I bought it back in early 2019, these Snektek modules was probably not delivered with RTC at that time, and that may the problem with my module not drawing any graphs and configure the time incorrectly. However, the initial Firmware delivered from last year with the unit, did show graphs, but have fixed scaling (max 400w),but did of course not have the advantage of remote access via the cloud service.
Post by jonathan » Fri Sep 11, 2020 4:20 pm
Alright, are you comfortable soldering the RTC module yourself? Then I will send it to you.
Post by fredivar » Fri Sep 11, 2020 4:29 pm
Hi Jonathan
thanks for clarification above. Understand the missing RTC module is causing my problem. Then I have two questions?
1 Possible to buy the RTC module which fit V2?
2. Any plan to change firmware which detect missing RTC and still will work "almost correctly"?( It is possible to set time in the epever solar controller which I have done, and assume this time could be read by the Snektek module?)
Post by fredivar » Fri Sep 11, 2020 4:33 pm
Sounds great, have been working as an electronic engineer for more than 30 years, so soldering is no problem
